Replacing a ceiling rose with a light fitting
Stradders
by Stradders » Sat Apr 14, 2007 1:05 pm
I'm trying to replace a ceiling rose with a light fitting, but am unsure about the wiring. From left to right, the existing wires are....
Brown - Black .... Red - Red - Red .... Black - Black - Blue
I have a 3 terminal block and a separate terminal block, i need to know which wires i need to bunch together in what way.
Thanks in advance :)
thedoctor
by thedoctor » Sat Apr 14, 2007 6:46 pm
See the replacing a light fitting project.
by sparx » Mon Apr 16, 2007 8:53 pm
Well done you looked & noted first most people discon. first then panic....
The really important wire is the first 'black' which is connected to the brown of flex next to it, it is really a 'red' as it's the switch wire coming back from wall switch, MARK IT with red tape/sleeving etc b4 disconnecting, then rest easy...
all three other reds go together in a spare connector & don't go to operate light, merely looping through.
remaining 2 blackes are neutrals and go to fitting neutral block, your newly marked 'black/red goes to fittings live term.block
regards SPARX
It is currently Sat Jan 11, 2025 1:46 pm
