replacing a 2 gang 2 way switch
lightning
by lightning » Sun Jan 27, 2008 1:11 pm
Can anyone offer any advice?
I am replacing the above switch which has
from top reading L to R
Com 1way 2 way
Bottom
1 way 2 way com
and there is a red cable in the top com, bottom 1 way
black cable in top 1 way and bottom 2 way
and a seperate red cable going from top com to bottom com
the new switch has two holes at top saying L
and four at the bottom plus a seperate Earth
L1 L2 L1 L2
any advice?
rhy
Re: replacing a 2 gang 2 way switch
by rhy » Sun Jan 27, 2008 8:51 pm
your two reds in the old switch (common) go to L in the new one the same way as they are top left common onto left L and bottom left common into right L the same way as before but now side by side.
and your 1 ways are now L1 and 2way L2.
so bottom left one way in to bottom left L1 bottom left 2way into bottom L2 and top 1 way into bottom right L1
in the end if i read it properly you should have a red in each L and a black in bottom L1,L2 and bottom right L1
hope this helps!!
lightning
by lightning » Mon Jan 28, 2008 7:51 pm
Thanks!!
It is currently Sun Dec 22, 2024 2:38 pm
