Cold Water Tank Size
COOKRJCV358TT
by COOKRJCV358TT » Tue Jan 29, 2008 9:08 pm
Could someone please tell me if increasing the size of my cold water tank in loft will this increase the hot water pressure, I have a gravity fed open vented system[/b]
nitro23456
by nitro23456 » Wed Jan 30, 2008 10:24 am
Better to tincrease the head on it ie the height between the tank and the taps in the rooms below.
In other words put the tank on legs.
bjbiker
No
by bjbiker » Thu Jan 31, 2008 6:49 pm
No increasing the amount of water will not give more pressure.
Check
1, size of pipe to bath min (22mm0
2, does it have any resrictions (ie, ball-o-fix valves) or lots of elbows
3, is any pipe work likely to air lock (high pints in loft etc)
If all these are OK! then raising the tank will be the answer, you should have min 1200mm from the Base of the tank to the shower rose on the wall.
Regards Bjbiker
It is currently Sat Nov 23, 2024 1:30 am
