Lighting problems
denzil
Lighting problems
by denzil » Thu Jan 31, 2008 10:09 am
I have recently fitted 4 hallogen lights to a bedroom and included a dimmer switch. the hallogen lights are 50W each so I used a 500W dimmer switch. The lights work fine, however, the bathroom light is not as bright as it was.
At the old centre light for the bedroom there were three cables going into the connection, have I maybe mixed up the wiring to cause this fault?
Many thanks for any info.
by ericmark » Sat Feb 02, 2008 12:04 am
You may have mixed up the neutral and the switch wire. This will mean instead of the bathroom light being connected to neutral it is connected to live of bedroom lights. If this is the case when you switch on the bedroom light the bathroom light will go out.
General sharaz
by General sharaz » Fri Feb 22, 2008 12:47 pm
yes u have definitly mixed the wired up ,u can locate the switch wires by using a contiuity tester,but u will need to open the ceiling rose and the switch to do this ,with the power off,connect the wires at the switch together ,then with the continuity tester probe the wires,when it makes a noise then that is the switch wire,u can switch on and off the switch to make sure ,the noise will sound when on and will not when off.the other way to identify the switch wire is just to look at the cable and see which one has a brown sleeve on ,then carry out this test to double check,as sometimes sleeving can be put on for a number of reasons.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 10:35 am
It is currently Fri Nov 22, 2024 5:00 am
