Joining a cable
bobanreg
Joining a cable
by bobanreg » Mon Feb 04, 2008 7:40 pm
Hi Guys,
I have damaged the 6mm cable to our shower which runs accross the loft.
Whilst it has not blown the fuse, which i have now taken out it does not look safe.
Is it o.k to just cut and rejoin the cable using a 30amp junction box?
Many thanks
BLAKEY1963
by BLAKEY1963 » Mon Feb 04, 2008 8:11 pm
bobanreg
personally i would try to replace the damaged cable
from where it oringates to the switch ( pullcord )
if this the case.
BLAKEY1963
by ericmark » Mon Feb 04, 2008 8:56 pm
If it is accessible then yes. If not accessible then will need to be crimped. With the latter normal to used shrink sleeve over whole job. But I would never send someone to do a job like that without first seeing it and it may be not the best option.
bobanreg
by bobanreg » Wed Feb 06, 2008 6:24 pm
Thanks a lot for your interest.
Tha cable is accessable,I have fitted a 45A DP switch where the cable was damaged and all seems well.
Do you have any doubts on doing this.
Cheers.
333rocky333
by 333rocky333 » Thu Feb 07, 2008 7:17 pm
Depends where the switch is located .
It is currently Sat Nov 23, 2024 6:16 pm
