Metal or hard material behind wall...
Sweetasfrank
by Sweetasfrank » Tue Feb 05, 2008 6:20 pm
Ok.
I've been redecorating my room for the past fortnight or so with ease..from wallpaper stripping to repainting and carpet stripping to re-carpeting etc.
As a lady, i'm quite pleased with how effortless i found most of the tasks..
However, i'm now in the process of installing furniture and assembling items such as wardrobes..cabinets etc.
I recently purchased a shelving-unit from Ikea that needed self assembly, which i managed to do without problems.
The plan was to mount the unit on my wall horizontally. To cut a long story short, i can't drill through the wall to mount it..
-This is the only wall free to mount it.
-The unit is more on the weighty side..rough guess, 27.7kg..more when i fill it up!
-The wall i think is made of plasterboard. Basically i can drill through it (say about an inch)..the material is soft, crumbly and off-white in colour, but then the drill bit hits something that i can only describe as metal...or a material just as hard..I ended up knackering a few drill bits...purchased new bits (about 2inches long) that were suited for metal work..Still no go. I switched the setting on the drill from 'drill' to 'hammer'..still no luck...
This problem runs right across the wall, though i managed to find a few safe spots that let me drill right through..
It's all very frustrating...
I was quite content in thinking i wouldn't have to pay to get a builder in, but is that the only option left?
Can someone please help? Would be eternally grateful!
kbrownie
by kbrownie » Wed Feb 06, 2008 10:15 am
Hi Sweetasfrank,
Have you tried masonary bits for drilling. It could be more than likely the wall behind the plasterboard is concrete blocks or stone. Metal bits will not go through stone/concrete with great easy. The drill should be on hammer at a slow speed if possible!
Regards
KB
It is currently Mon Nov 25, 2024 10:43 pm
