Phone box shower
JonMcKay
Phone box shower
by JonMcKay » Wed Feb 06, 2008 4:21 pm
I have an old phone box that is used as a shower cubicle. I believe it was installed about 20 years ago. The paint on the inside is starting to flake off. I have no idea what sort of paint it is. What should I use to replace it? I tried Hammerite but it immediately started to flake. Any ideas?
arbucleuk
by arbucleuk » Mon Mar 17, 2008 8:57 am
primer simple
Ruff up the old surface with a hevey grit paper get a good metal promer and give a couple of coats then is should stick fine.
You may want to try adding pva to the primer as well about 1 to 5, 1 part pva to 5 parts primer.
hope it helps and good luck
It is currently Mon Nov 25, 2024 11:46 pm
