Painting over woodstain.
samk
by samk » Thu Feb 07, 2008 12:17 pm
Help with painting over woodstain. Have tried primer, undercoat x 2, gloss x 2. Stain still comes through. Want to keep the door.
big mark
Re: Painting over woodstain.
by big mark » Sat Feb 09, 2008 12:07 pm
[quote="samk"]Help with painting over woodstain. Have tried primer, undercoat x 2, gloss x 2. Stain still comes through. Want to keep the door.[/quote] have you tried a water based primer ,seems the oil in the paint is activating the stain
ROGERS
PAINTING OVER WOODSTAIN
by ROGERS » Sun Feb 10, 2008 9:05 pm
Have you tried stainblock ? otherwise try to get paint with a different solvent such a methyl based paints
chriss
by chriss » Thu Feb 14, 2008 4:05 pm
try using a Zinzzer coverstain. It will block the stain ans allow you to paint with ordinary oil based top coat
thepainterman
by thepainterman » Sun Feb 24, 2008 11:53 pm
Use zinsser B-I-N it's shellac based,unbeatable for what you intend doing.
Apply 2 coats to be sure of a good seal and leave for 5-7 days for best results,after that time,you can apply and water based or oil based coatings.
It is currently Fri Nov 22, 2024 11:22 pm
