PIPEWORK NEAR HOT WATER CYLINDER/AIRING CUPBOARD?
stevehayes
by stevehayes » Fri Feb 08, 2008 12:46 pm
how many pipes, both hot and cold, should there be in my airing cupboard?!! I have the vent and hot water draw off's from the top of my hot water cylinder (inclduing the 450mm min offset), I have a sepearte hot and cold feed pipe to my shower (which is a manual mixer over my bath), I have a grundfos pump (for central heating i believe)?? and a motorized valve, (3-port valve i believe)?? and a primary flow and return pipe coming up from my boiler which is directly downstairs below in the kitchen. I think I have a primary feed and primary vent pipe also passing through my cupboard too! But do the central heating pipes run through my cupboard too? I'm a bit confused but want to learn??!! Because I can't put a name to ALL the pipes and it's bugging me!!!
dcc
by dcc » Fri Feb 08, 2008 8:40 pm
is there any way of posting a picture in these forums? if you can then ill be happy to label them all for you
thedoctor
by thedoctor » Fri Feb 08, 2008 9:12 pm
We are working on a page for adding images but its not ready yet I'm afraid.
nitro23456
by nitro23456 » Sat Feb 09, 2008 10:49 am
Check out this thread:
https://www.diydoctor.org.uk/forums/view ... light=leak
Four posts up from the bottom - I posted some pics that should answer your questions.
It is currently Fri Nov 22, 2024 5:48 pm
