by kbrownie »
Sun Feb 10, 2008 5:39 pm
Fergie123,
sounds like you have connected the wires wrong when you did it.
Check that all the reds(live) probally 3 are together, that the in-coming black (neutral) is contact with the out going black (neutral) to blue side (neutral) of light and the black switch wire (which should have red tag or sleeve on it) is connected to brown (live) side of light.
all earths connected together
If your wiring is new harmonized colours, Reds=Browns, Blacks=Blues
If it's end of loop there will be no out going neutral or live but wire as above but without them included.
Best of Luck,
Remember be safe and always safely isolate the circuit you are working on.
KB
