Mix for White Render
Ask questions and find answers on a range of subjects relating to self build projects
Millo
by Millo » Sun Feb 10, 2008 6:58 pm
Can anyone tell me how to mix white render for an external wall? Do I just use white cement and light coloured sand or do I need to add a colouring?
watcha
by watcha » Wed Mar 25, 2009 6:40 pm
White Mortars
White mortar is made with white masonry cement, or with white portland cement and lime, and white sand
Regards
Watcha
rosebery
by rosebery » Wed Mar 25, 2009 8:18 pm
Yes use a light coloured sand and make sure that you use the same colour throughout - otherwise you'll get a patchwork effect. White cement is a very good idea as it allows the colour to stand out more.
For the colour itself use cemetone dye
The most important thin is that mixes are equal gauge using a bucket. Guage the dye with a cup.
Best of luck with it.
It is currently Fri Nov 22, 2024 3:41 pm
