Block paving repair
baillib
Block paving repair
by baillib » Mon Feb 11, 2008 1:33 pm
I have had to lift a section of my block paved driveway. How far below the existing surface should I set the sand layer for relaying
grooverider991
Re: Block paving repair
by grooverider991 » Mon Mar 31, 2008 10:04 pm
[quote="baillib"]I have had to lift a section of my block paved driveway. How far below the existing surface should I set the sand layer for relaying[/quote]fill the area with sharp sand and place the blocks back in the are where you removed them making sure they protrude about half an inch above the surrounding blocks then cover with kiln dried sand or play groung sand and use a whacker plate to compact down to the same level as existing surface
It is currently Sat Nov 23, 2024 11:50 pm
