Outside TAP
Ricardo
Outside TAP
by Ricardo » Mon Apr 16, 2007 4:36 pm
Hi all
I wonder if you can help me. My outside tap works fine without a hose attached, but when I attach the hose it leaks everywhere from the Hozelock device at the tap end. I have changed the hozelock thing but it's still leaking. Do you have any suggestions as to what might be causing this?
Many thanks
Ric
DONFRAMAC
Outside tap
by DONFRAMAC » Thu May 10, 2007 5:06 am
You should have fitted a tap which has a 3/4 inch BSP thread on the output spout. Hoselox make the exact screw-on fitting for it, with the other end having an O-ring seal, for the main hose coupling to snap onto, after unwinding the whole hose from inside the drum.
Ricardo
by Ricardo » Fri Jun 01, 2007 10:29 am
Thanks. I have all that and still it leaks
DONFRAMAC
Outside tap
by DONFRAMAC » Fri Jun 01, 2007 8:07 pm
Might be a rough thread on the tap's 3/4 BSP spout. ---- Try packing-out the thread using plumbers PTFE tape, and re-fit the HOZELOX adaptor. (rough threads can be cleaned-up -- engineers have hard metal combs for that job, but a steel-bristled brush may do. Check the thread with your finger-nails.)
It is currently Mon Dec 23, 2024 4:34 am
