flushing ch system
ernwatson
flushing ch system
by ernwatson » Sat Feb 16, 2008 10:34 am
how do i confirm central heating system needs flushing
Oliver_murphy
by Oliver_murphy » Sun Feb 24, 2008 7:44 pm
check for cold radiators, then check for cold spots in rads.
Normal process for sludge, is to clog up the base of the rad, so you would expect the rad to be HOT at the top and COLD at the bottom. This would indicate sludge,
ernwatson
power flush
by ernwatson » Sun Feb 24, 2008 9:49 pm
thanks oliver for taking time to reply
reason i was questioning for power flush was that bt engineers said power flush was neccessary as my boiler was firing up every few seconds and cutting out they said system was sludged up
but my radiators are running perfectly so i wondered if it was neccessary to spend £700 which they quoted me
once again thanks ernie watson
by htg engineer » Mon Feb 25, 2008 6:33 pm
Do you mean BG ?
Another rip off by BG, powerflush or new boiler. That's all they seem to advise.
