I'm replacing a ceiling rose with a Flush Ceiling light fitting. I've got an upstairs & downstairs circuit system where the wires go from one light to the next and so on.
So far I have taken off the ceiling rose and put the new flush plate up with the new fitting. However, the new fitting only has two connection points in total for the core wires (live/neutral) - and I have 3 cables with 3 wires each coming from the ceiling.
I have identified the switch cable, but i don't know what goes where? Do i need to squeeze all 3 lives into the one connection point, and all 3 neutrals into the other connection point? I don't think they will fit like that so need some advice on what the correct wiring is.
Your help would be appreciated.
Ta
