dado rails
pamnovice
dado rails
by pamnovice » Sun Feb 17, 2008 12:49 pm
how high should a dado rail be from the skirting board, also how do i join two pieces together along a straight wall? :?:
droylsden18
by droylsden18 » Tue Feb 19, 2008 8:08 pm
Traditionally dado rail was used to stop chairs damaging walls so they were set at the height of the back of a chair, 900mm to 1 metre off the floor.You just need to be careful with the height of your windowsill and consider how you want it to finish at the window.
To join dado along a wall you should mitre both pieces glue and pin them together.
It is currently Fri Nov 22, 2024 10:59 pm
