size of brackets needed for secure fixing of shelves
gaby
by gaby » Mon Feb 18, 2008 2:35 pm
I want to fix an MDF shelf to a wall . The shelf is 208 cm long, 40 cm deep and 3 cm thick. It is for storage /display of clothes ie jumpers, T shirts etc. I want to use 3 wall brackets. The wall is brickwork to the sides but the central bracket will be fixed to a timber post in the wall.(This part of the wall has a partially boarded up window behind it -hence the wooden post ) I was thinking of using either cantilevered brackets or mitred brackets. Can I use brackets which are 20cm by 20 cm or does the bracket have to be the full depth of the shelf ie 40 cm . I would like to use as small a bracket as possible but need to ensure the shelf is secure and can take the weight of the clothes. Any advice would be much appreciated.
ALDA
by ALDA » Wed Feb 20, 2008 8:50 pm
YOU COULD FIX A BATTEN TO BOTH END WALLS AND FIX TIMBER SUPPORTS SPANNING THESE BATTENS BACK AND FRONT TO PROVIDE SUPPORT FOR YOUR MDF SHELF IT WOLULD ALSO GIVE THE APPEARANCE OF A MUCH THICKER/FLOATING SHELF.
It is currently Sun Dec 22, 2024 2:33 pm
