EARTHING UPGRADING AND LEGAL REQUIREMENTS
6 posts   •   Page 1 of 1
Retrovir
by Retrovir » Mon Feb 18, 2008 3:39 pm
Do I legally have to have my earthing and bonding upgraded when I have a new consumer unit installed by an electrician, if I am happy with the existing 6mm
pyro_mania
by pyro_mania » Mon Feb 18, 2008 10:08 pm
Main equipotential bonding is 10mm so yes.
by sparx » Mon Feb 18, 2008 10:56 pm
Both the trade organisations we belong to [ECA/NAPIT] insist on it before doing board changes, we are also strongly advised to do a Periodic Inspection/test first to check for problems in existance already eg low IR's
which may cause RCD's to trip if none fitted previously otherwise customer might say we have created a fault, rather than finding one,
if you don't upgrade at a board change when will you?
regards SPARX
Retrovir
by Retrovir » Mon Feb 18, 2008 10:59 pm
[quote="sparx"]Hi,
regards SPARX[/quote] Thanx very much for your help Sparx
Retrovir
juli-juan
by juli-juan » Wed Feb 20, 2008 8:59 pm
yes because he should test it and must check all earthing and bonding cables all household electrics should be tested
juli-juan
by juli-juan » Wed Feb 20, 2008 9:00 pm
[color=red][/color][size=18][/size]
It is currently Tue Nov 26, 2024 9:13 am
