plastering tape
cammy4366
plastering tape
by cammy4366 » Tue Apr 17, 2007 9:12 pm
I've moved into a house where a door opening has been plasterboarded over and skimmed, there is a crack the whole way around it now. I've removed the plasterboard and have taken 15m out of the old door standard so the board is flush (-3mm) with the stone plastered walls. what is the best kind of plaster tape to use to form a bridge between stone and plasterboard to ensure it doesn't crack when i redo it?
thedoctor
by thedoctor » Tue Apr 17, 2007 9:57 pm
Its called scrim Cammy and its a very fine mesh on a roll which will prevent cracking. See our project on plastering and scroll to the bottom to see a roll of scrim.
cammy4366
by cammy4366 » Wed Apr 18, 2007 8:01 am
Thanks, but i've used that tape before on joints between plasterboard and plastered stonework without any success. is there a stronger or more suitable product as opposed to that plastic mesh? I've been told there is an older product that was more like a rope type mesh for joins. can you still buy it?
It is currently Thu Nov 28, 2024 1:56 pm
