Removing paint from plastic
Lorraine Mahy
by Lorraine Mahy » Sat Feb 23, 2008 11:50 am
Does anyone have any tips on removing dried paint from the plastic surrounding double glazed windows?
Fishie42
by Fishie42 » Tue Feb 26, 2008 1:21 pm
X-tex paint and varnish remover.
You can buy it from B & Q or order online, I've just used it to strip paint from a door, works wonderfully. Will do 2/3 layers at a time. Is a bit more expensive than other stripers but is non-solvant based and can be used on a huge range of things including plastics.
I'd do a trial area first to make sure its ok on your plastic!
pbp
by pbp » Fri Feb 29, 2008 1:48 pm
HI..Just to clarify that the product is called Home Strip and not X-Tex. X-Tex is a product by the same company, but it is used to remove artex. You can also find it on the project pages under paint stripping.
It is currently Sat Nov 16, 2024 6:13 pm
