plumbing
modbarra
plumbing
by modbarra » Mon Feb 25, 2008 8:11 pm
water overfow flowing,,,,,, looked in main cold water tank and hot water appears to be coming in from a bottom pipe.! normal? thanx
plumber1988
Re: plumbing
by plumber1988 » Wed Feb 27, 2008 11:26 pm
[quote="modbarra"]water overfow flowing,,,,,, looked in main cold water tank and hot water appears to be coming in from a bottom pipe.! normal? thanx[/quote]
This is totally normal for the hot water to be comin from the bottom pipe the ball valve may be faulty if it is just replace it and the water level will return to normal if the ball valve is not faulty then try adjusting it to about an inch below the over flow pipe orrifice this should rectify the problem.
NOTE: if the ball valve is faulty then it will be submerged in water or the water will be dirty.
hope this helps
modbarra
by modbarra » Thu Feb 28, 2008 8:21 am
thanx.... seems to have sorted it self, but will replace ball valve as it does look past its best... ta
It is currently Sat Jan 04, 2025 10:54 am
