TILES ON MDF-THE ULTIMATE SIN????
Suprastone
by Suprastone » Mon Feb 25, 2008 8:48 pm
HI GUYS CAN I TILE ON MDF? I KNOW ITS NOT IDEAL BUT ITS TO BOX IN A CONCEALD CYSTERN AND SOIL DOWN PIPE, AREA IS NOT GOING TO GET DIRECTLY WET!
WAS GOING TO USE 9MM MDF AND PRIME WITH 100%PVA THEN USE WATER PROOF ADHESIVE AND GROUT. ANYONE ELSE DONE THIS?
THANKS
Paul_BG
by Paul_BG » Tue Mar 04, 2008 2:20 pm
Hi, I had the same challenge, and when I looked at various forums the advice was not to do it. However, I have tiled an area of MDF where I boxed in heating pipes.... its in my downstairs cloakroom which doesn't experience any damp. I primed the MDF with standard primer and attached the tiles using the Wickes equivalent of No More Nails, then used standard grout when glue was dry. The tiles are absolutely solid and after two months there is no sign of anything moving or falling off! Good luck. :)
PST
by PST » Wed Mar 05, 2008 9:58 pm
Best bet is Bal Mosaicfix , used and stuck like nobodys business
rosebery
by rosebery » Sat Mar 08, 2008 5:01 pm
DONT prime with PVA. Use an acrylic primer like BAL APD.
9mm is going to be thin and will flex. If you haven't boxed yet don't use MDF use WPB ply and I'd suggest a minimum of 12mm. 18mm would be better. Prime with APD and use a flexible adhesive. Bagged is better than tubbed but if you use Whitestar or equivalent tubbed would be OK.
Nester
by Nester » Wed Mar 19, 2008 2:57 am
May be worth remembering that areas which will not obviously get wet in normal use may nevertheless get wet because of totally unforseen circumstances - floods, roof leaks, pipe leaks etc.
MDF and Chipboard both swell if in contact with damp and will shed tiles. WPB, Concrete or Plaster Boards are more resilient.
It is currently Fri Nov 22, 2024 5:08 am
