Fixing wall mounted basin
kbrownie
by kbrownie » Tue Feb 26, 2008 10:57 pm
Hi all,
I have recently purchased a new bathroom suite. The basin is wall mounted with chrome waste, no fixings or fixing instruction puzzled on the correct method install it onto wall?
Could someone PLEASE offer me some guidance,
Cheers to all with helpful advise
KBl
Rico
by Rico » Thu Feb 28, 2008 9:58 am
Hi kbrownie,
The basins dont always come with fixing kits.
There are a couple of ways for them to be hung depending on type of basin.
There are flat hook type brakets which you fix to wall and then hang then basin on them.
More traditional brackets which look like shelf brackets angain fix them to the wall then hang the basin off them.
Finally you can get Fischer Basin Fixing Kits which are long bolts that screw into the wall and you then attached the basin through the holes to the bolts using nuts and washers provided.
http://www.awin1.com/pclick.php?p=20729 ... 071&m=1228
Hope this helps.
Rico
kbrownie
by kbrownie » Fri Feb 29, 2008 4:22 pm
Hi Rico,
thank's for reply, i'll give them a look over and see which one suits best.
You've been a great help and cheers
KB
dogsella
by dogsella » Sun Mar 02, 2008 11:54 pm
ive seen the fischer bolt method before and the plastic bush had an elongated cam type adjuster to level the basin..but i dont know where they sell them. does anybody know where to get them?? cheers
It is currently Sat Nov 23, 2024 1:22 am
