toilet has to be raised
6 posts   •   Page 1 of 1
PTMD
by PTMD » Wed Feb 27, 2008 12:01 am
a high cast iron soil stack and the toilet im gona change is sittin on a 1 inch wood base so it can fit waste. is there a toilet with a wast outlet 8 1/4 inchs floor to center or is there something else i can do :?
polymol
by polymol » Wed Feb 27, 2008 5:04 pm
I had the same problem a few weeks back. In the end I decided to lower the soil pipe by 2 inches....a messy job but well worth the effort At first I thought about raising the toilet but decided it would look daft.
Good luck
PTMD
by PTMD » Wed Feb 27, 2008 6:53 pm
DID YOU HAVE TO CHANGE THE SOIL STACK TO LOWER IT.
chrisroberts
by chrisroberts » Sun Mar 09, 2008 12:17 pm
[quote="PTMD"]DID YOU HAVE TO CHANGE THE SOIL STACK TO LOWER IT.[/quote]
Hi there, have to tried using an off set pan connector, you may get the height difference using one of these.
PTMD
Soil pipe info needed
by PTMD » Mon Mar 10, 2008 8:22 pm
Thanks for the info on soil stack dilema. Put a new floor in 18mm chipboard floor covered with lamiate tile's worked a treat. Another question for you. I have been asked to put a bathroom in to a bedroom and they want the soil stack inside the house not out side. are there any bylaws that govern taking a soil stack out through a wall under the damp proof coarse and connecting to existing soil run in the garden, and bylaws around putting a bathroom in.
Regards Dan
Rico
by Rico » Tue Mar 11, 2008 9:26 am
PTMD,
Not sure on regs on soil stack, but you we need to notify local building control anyway as you are putting in a "NEW INSTALLATION" so you can ask them at that time.
Hope this helps
Rico
It is currently Mon Jan 06, 2025 11:40 am
