leaking hot water tank again
markspark
by markspark » Wed Feb 27, 2008 10:28 pm
I have a leaking hot water cyl to replace. The return pipe from the boiler has a gate valve but the feed has not will this be ok when the cyl is drained :?: Also i have an expansion tank in the loft as well as CW storage do i need to do anything with the exp.tank to replace HW cyl :?: Finally ,exp.tank has been filling and coming out of overflow now and again could this be due to leaking HWcyl or not as ballcock valve seems ok :?: THANKS
It is currently Fri Nov 22, 2024 4:12 pm
