Low water pressure
8 posts   •   Page 1 of 1
odd1
Low water pressure
by odd1 » Thu Feb 28, 2008 2:24 pm
I have a small guest house with 9 bed rooms of which 3 are at the top of the building which consists of a cellar, ground floor and two other floors with half landings in between.
My problem is we are constantly having problems with low water pressure at the top of he building wh :? ere we have three rooms with sinks and showers.
At the moment we have three people staying in the rooms who work for the same company and all get up at
the same time to take a shower.
Is fitting a pump to the mains supply the thing to do and if so how?
Can you help?
Thanks in advance
:( Tony
Rico
by Rico » Thu Feb 28, 2008 5:10 pm
Hi there,
No it is against water regs to fit pump to mains cold supply.
Rico
by htg engineer » Thu Feb 28, 2008 5:39 pm
You need to check the flow rate, when 2 or 3 taps are opened at the same time then the flow rate will be poor.
Is it the hot/cold that is poor or both ?
It is against the water regulations to fit a pump to the mains cold water, you can only pump stored cold water.
Is the mains water pipe adequate for your house ? probably fine for a family of 4 or 5, or a house with 2 bathrooms - but not for a guest house.
odd1
by odd1 » Fri Feb 29, 2008 9:37 am
Thanks Rico & htg engineer
We have a larger water mains pie to the building so i don't think its that.
I did not know it was against water regulations to fit a pump to the mains so thats somthing I'v learnt, is that somthing to do with metering if so we have a water meter i was thinking of putting the pump past the meter do you know if this can be done?
Its just the showers really that are effected they are electric with cold water feeds.
Thanks again
Tony
by htg engineer » Fri Feb 29, 2008 12:03 pm
You'd have to fit a large cistern of some sort - where the mains cold water would fill via a float operated valve - then the water from the cistern could be pumped. The water board can only guarantee that water is safe to drink if there are no alterations to the mains cold water supply, fitting a pump is against these regulations.
Has this always been a problem - or has it just started ?
odd1
by odd1 » Fri Feb 29, 2008 12:19 pm
Thanks Rico
Your A star :D
Rico
by Rico » Fri Feb 29, 2008 12:57 pm
Hey odd1,
No problem,
It is not to do with metering it is to do with the rate at which water is drawn off the main.
It can effect pepole further up the line from, ie you switch on pump and supply dorps to next property along.
Hope this helps.
Rico
odd1
by odd1 » Fri Feb 29, 2008 3:36 pm
thanks htg
Well explained
It is currently Fri Nov 22, 2024 4:45 pm
