Noisy boiler - kettling?
allotmentboss
by allotmentboss » Fri Feb 29, 2008 8:08 am
I wonder if you can help.
Over the last few days my combi boiler (Ariston Genus 30) has started developing a noise whenever I draw domestic hot water. The noise builds up over about 30 seconds, starting out like the sound of a kettle starting to boil and ending up as a continuous loud low hum - like the sound of an articulated lorry braking heavily.
It doesn't make any unusual noises if we have just the central heating on. So,
Just central heating = quiet.
Just DHW = noisy
DHW + CH = noisy.
A month or so ago I did the following work on my system:
(1) Changed some piping for the bath's hot water. This is a long way from the boiler, and drawing water from any tap makes the noise. So, I believe this to be unrelated.
(2) Drained the CH system to fit a new radiator, and flushed it with desludging solution.
If this is "kettling", what's the best way to solve it?
Many thanks
Oliver_murphy
by Oliver_murphy » Fri Feb 29, 2008 1:51 pm
deslude and descale the system. Make sure its done properly.
by htg engineer » Sat Mar 01, 2008 3:36 pm
It could just be the water to water / plate heat-exchanger is scaled up, you an remove the plate heat-ex flush and clean the ports etc.
Alternatively fit a new heat-ex but they're normally quite expensive.
Hope this helps
It is currently Fri Nov 22, 2024 5:13 am
