by Andrew Betteridge »
Sun Mar 02, 2008 1:12 pm
Don't lose youself in the technical stuff Eric, the simple truth is the majority of British homes have oboslete fuseboards which were never designed to take RCD's and RCBO's to provide the protection now required for certain additions to existing Electrical Installations after June 2008.
For a specific example of this all Crabtree Starbreaker Consumer Units made before July 1992 do not have any parts available apart from MCB's, so even though to most people they look like nice new modern units they are effectivly oboslete.
The majority of Homes do not have any RCD protection at all built into the Installation and the overall standard of Electrical Installations in British homes is very low. Hence these Homes will require upgrading prior to some relatively simple work being carried out, with replacing the Consumer Unit being the most cost effective way of complying even at several hundred pounds. Bear in mind in a Kitchen you could have three or more circuits to add RCD protection too, Cooker, Sockets and Lights.
This however means of complying with the regulations will have to be assessed on each job as there are many variables, for example if you wired a new central heating boiler from a existing switched fused spur, ran the cables surfaced fixed in mini-trunking and through the timber floor joists correctly positioned then you would not need a RCD, however if you chased cables into the wall to get to a hard wired room thermostat you would, replace the room with a wireless one, then you wouldn't and so it goes on.
The days of stating "this is how it is done" are numbered with more thought having to be put into design.
Regards the fines for not complying with part P, it is all true!. personally I think Part P is Legislation that needs reviewing by the Government as it was not drawn up correctly, it was never advertised as the Government paid for TV adverts to be prepared then wanted the TV companies to air them free as public information, which the TV companies refused to do, the Councils receive no income from the notification schemes and many shredded the early notifications as they did not have resources to deal with them, only when the Insurance Companies told them to behave did something get done about it. How the Govenment expect the general public to know about or understand the Building regulations Part P I really do not know.
There is now a new system in place where Electricians are being asked to notify the operators of the Competent Persons scheme thay are in of law breaking Electrical work, the scheme Operators will pass the information onto the Local Authority Association who will notify the Local Council responsible for the area then monitor that Council to see that action is taken and the local Building Control do not ignore it.
Strange thing is at the moment if a dodgy Electrician is not caught out in six months nothing will be done about it unless there is death or injury, the Government are taking steps to extend this period to two years.
DIY Electrical work is not illegal, but it is becoming more involved and complicated, with restrictions on what can effectively be carried out due to the added cost of Building Control Notification and Inspection fees making it cheaper to pay a Registered Electrician to do certain types of work.
It will be intresting when firms such as MFI and B+Q start quoting for Electrical work as part of Kitchen and Bathroom replacements to be carried out from June 2008 onwards to see how they deal with the changes and the costs involved.
Andy
