What is the best stuff to use when filling in gaps (corners)
stoz
by stoz » Sat Mar 01, 2008 8:59 am
Can anyone tell me what to use to fill in the corners where the plaster board does not meet (corners), before plastering.
Thanks in advance :cry:
kbrownie
by kbrownie » Mon Mar 03, 2008 6:01 pm
Hi you can buy a self adhesive tape from Builders Merchants and DIY stores, Look in the plastering dept or ask. It's made of nylon and comes in rolls a bit like the plasters scrim and then can be filled out and will prevent cracks re-appearing.
Regards
KB
Aidan
by Aidan » Mon Mar 03, 2008 8:47 pm
What i normally do is use skrim tape (as above said) down the join and then mix a little dry line adhesive and push it in to the gap over the skrim getting in as much as possible so there are no gaps. Let it go off for about 20-30 minutes then get a wet brush and brush off any excess leaving you with a gapless joint with the added protection of the skrim tape
It is currently Sat Oct 05, 2024 9:21 am
