non maintained lights to maintained lights
danny001
by danny001 » Sat Mar 01, 2008 9:34 am
hi,
can a non maintained emergency light be converted into a maintained light to be switched on and off at will,
or will this break the gear in the non maintained
thanks
by ericmark » Sat Mar 01, 2008 11:56 am
Since the maintained versions are more expensive than non-maintained one would assume you will need new lamp. I know in some of the places I have worked to reduce stock levels we only kept maintained on the shelf and just left out the switch wire if used in non-maintained locations or bridged it where a Sustained was required but your unlikely to find that to be the case.
It is currently Wed Oct 02, 2024 5:31 pm
