by sparx »
Wed Apr 18, 2007 5:49 pm
It doesn't matter that you are 'going for Niceic registration' you are breaking the law by altering con.unit wiring, you must be Partp registered before doing this work.
Having said that,
If you mean to fit seperate isolator switch in an enclosure and add extra 'tails' or to use a double 'Henley block' to extend 'tails' either way you would be illegally either breaking cut out fuse seal to pull fuse or doing it 'live' which is more dangerous than people realise and against the law. take care,
