plastering after dampcourse.
david c
by david c » Sun Mar 02, 2008 9:07 pm
hi can anyone tell me if its ok to use browning on an internal wall after it has had a new dampcourse done?
tucny
by tucny » Fri Mar 07, 2008 10:32 pm
NO!
The plaster must be a strong sand/cement mix with water proofer/salt inhibitor. Try using a ready mixed system such as Limelite.
It is very important that you use a correct plaster otherwise you may have problems associated with salts.
david c
by david c » Tue Mar 11, 2008 1:05 am
[quote="tucny"]NO!
It is very important that you use a correct plaster otherwise you may have problems associated with salts.[/quote]
thank you very much for the info.
when you say the plaster must be a strong sand/cement mix, could you tell me what ratio you would recommend please.
thanx agian
david
goose
by goose » Wed Mar 12, 2008 7:00 pm
Added to this, I've had to rebuld the wall under my bay window and replace the dampproof course there, its going to be plastered by a professional with me buying the materials and doing the dogbody'ing - he said that he cement the wall then plaster on top - would that be ok? (after reading the above)
tucny
by tucny » Sat Mar 22, 2008 10:46 pm
As said using a premixed renovation plaster is ok. or if mixing his own plaster he must use 1 part ordinary portland cement to 3ish parts good quality washed loam free sharp sand with a salt inhibitor/water proofer.
Sulphate salts that are often present in masonry are washed into the plaster by dampness. If these are able to migrate into the plaster (which they can if the correct plaster mix is not used - the above type of plaster mix is designed not to allow this), even if this is a cement based render then sulphate attack can occur. Also the correct type of plaster is required to prevent hygroscopic salts such as chlorides and nitrates from migrating to the plaster surface as these will absorb moisture from the atmosphere surrounding them.
There is a science behind the plaster and the use of this is more important than many people realise.
It is currently Mon Sep 16, 2024 8:54 pm
