hi, i have the above timer on my gas central heating system, i would like to change it to a 5/2 or 7 day digital timer with independant water and heating timing? it has 3 wires going into the bottom of it, 1 goes to a fused switch which goes to another fused switch which is the immersion, the other 2 wires go to a box which goes to supplies the motorised valve, cylinder thermostat and the pump. is this a simple exchange or do i need to get someone in? im a fairly competent diy'er. i would also like to add a thermostat somewhere as we dont have 1, would this be straightforward too, the boiler is downstairs and the hot cylinder is upstairs if this helps? regards trevor
________
Ford Ranchero Rio Grande picture
