Plastering behind wood burner
peterandalisonmoore
by peterandalisonmoore » Wed Mar 05, 2008 9:50 am
I have a problem behind my wood burner relating to the plaster peeling due to the heat. Before I re-plaster it does anyone know of a method that will prevent it re-cracking? I have heard that if I use a lime based mortar this will cure the problem? :roll:
kbrownie
by kbrownie » Wed Mar 05, 2008 5:11 pm
peterandalisonmoore,
If your stripping plaster off, i'd suggest you don't plaster it but render it instead. That's what I did with mine, never had a problem!
Regards
KB
It is currently Sun Nov 24, 2024 3:34 am
