Vinyl floor tile roller
mikekerin
by mikekerin » Sat Mar 08, 2008 12:30 pm
I am intending to lay Amtico tiles on my kitchen floor. Amtico recommend rolling the tiles with a 100lb (45kg) roller 1 - 2 hrs after laying. I have searched the internet and tool catalogues in vain for such a roller. Does anyone know where I could hire or purchase such a tool?
ALDA
by ALDA » Sat Mar 08, 2008 8:28 pm
MK,
YOU COULD IMPROVISE, USE A WATER FILLED GRASS/LAWN ROLLER .
A STEEL GRASS/LAWN ROLLER WOULD WORK ALSO.
IN BOTH CASES, USE OF A SHEET LAYED OVER THE VINYL TILES WOULD PROTECT TILES FROM DAMAGE.
A PINT OF WATER WEIGHS 1lb SO DOING THE MATHS YOU WOULD NEED TO AQUIRE A WATER FILLED ROLLER WITH A MINIMUM CAPACITY OF
12 1/2 GALLON.
I HAVE SEEN THESE ROLLERS IN GARDEN CENTRES BUT CANT SAY WHAT FILLED WEIGHT IS!
ALDA.
rosebery
by rosebery » Mon Mar 10, 2008 10:04 am
I know the sort you mean - only about 3 or 4" diameter and very heavy.
Have you tried a flooring shop?
mellosoul
roller
by mellosoul » Fri Mar 14, 2008 8:17 pm
A local hire-it shop should let you use one for a daily rate as purchasing oneis expensive just for one or two jobs but be careful they are heavy.
It is currently Mon Nov 25, 2024 9:51 am
