concrete arch for back garden wall
goose
by goose » Sat Mar 08, 2008 3:06 pm
I want to try and make a concrete arch for my back garden wall. The arch itself will be a very 'shallow rise' with the centre only been around 1.5 inch about the ends (if that makes sense). I'm assuming that I should use reinforcing rods?
I'd like to make it the same height as a concrete block and the same width as two blocks. it would be the width of a gate opening + extra 1/2 block width each side.
What mix should I use for the concrete? How many rods + how to fit them?
How to make the mold?
many thanks.
grooverider991
by grooverider991 » Wed Apr 02, 2008 7:14 pm
Hiya,mix the concrete 4 to 1 and use a couple of 12mm reinforcing bars which you can bend easily to the arc shape,hope this helps
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 26, 2010 8:49 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sat Nov 23, 2024 11:38 pm
