Fixing plasterboards on walls
dwyvernt
by dwyvernt » Tue Mar 11, 2008 6:09 pm
From my research on the web, the convential way of fixing plasterboards to walls is either the baton method or dot and dab. Is it acceptable to fix plasterboards using selftapping masonry screws?
kbrownie
by kbrownie » Wed Mar 12, 2008 7:31 am
Hi, NO!
Due to the fact that most walls are uneven and not level, fixing in such away would lead to joints on boards not matching and lining up correctly.
The screw would also not hold very well as the surface behind the plasterboard would not gaurantee a firm support, which would also lead the screw penetrating straight through the board and not holding it in place.
So not advisable. regards
KB
dwyvernt
by dwyvernt » Wed Mar 12, 2008 9:49 am
Many thanks for the reply
matt h
by matt h » Fri Mar 28, 2008 3:03 am
no, but can use new sealant fixitives which are faster and ensure no cold voids :wink:
It is currently Sun Nov 24, 2024 1:59 am
