PLASTER CORNICING
yves 13
PLASTER CORNICING
by yves 13 » Wed Mar 12, 2008 9:31 pm
WHAT IS THE BEST WAY TO REMOVE A LATHE AND PLASTER CEILING WHILST PRESERVING THE ORIGINAL PLASTER CORNICING?
rosebery
by rosebery » Wed Mar 12, 2008 11:34 pm
Why do you want to do that? If it's a proper plaster (ie done by the spread rather than the stick on stuff) cornice it'll be virtually an integral part of the ceiling as it will have been done at the same time as the original ceiling.
If the old ceiling is in a bad state of repair then board over it and skim. Have to be clever matching in with the cornice though but it should be doable.
Taking a ceiling down is quite unecessary and a seriously fithy job.
yves 13
REMOVING A LATHE AND PLASTER CEILING
by yves 13 » Thu Mar 13, 2008 7:03 pm
IT NEEDS TO BE DONE AS THE CEILING IS BULGING AND CRACKED!! BUT I REALLY WANT TO SAVE THE CORNICING I'VE BEEN TOLD I CAN CUT IT OUT WITH AN ANGLE GRINDER IS THIS CORRRCT?
It is currently Sun Dec 22, 2024 1:45 pm
