tool for cutting wall to hide wiring
manni
by manni » Thu Mar 13, 2008 9:45 am
not sure if this is in the wrong forum but i need to route a wire in the brick work of the bedroom wall, what is the best tool to cut a channel?
Should i use an angle grinder to cut two lines down the wall and chisel out the middle?
I hope you can help
Martin
by ericmark » Thu Mar 13, 2008 9:16 pm
There is a special tool similar to two angle grinders which cuts two groves set depth and distance apart then a cold chisel in a SDS drill with rotor stop will take out material between the two lines with ease. Getting right depth with angle grinder is a bit hit and miss and straight lines not easy either.
It is currently Mon Dec 23, 2024 1:22 pm
