Hello
I have a problem with my heating and I noticed this forum so I thought I'd try and see if anybody here can help me with it.
In doing up my upstairs bathroom I have removed the radiator, intending to put in a towel radiator in about 2 weeks. In doing this I partially drained the system from a tap in a downstairs radiator after stopping the refill valve in the F & E tank in the loft. I didn't empty the system fully. I then used some caps to close the two pipes in the bathroom. I then went let F & E refill and started bleeding the upstairs radiators.
Now when I switch the heating on the upstairs radiators heat up but the downstairs ones stay cold. I keep bleeding the upstairs radiators and occasionally get bursts of air out. The downstairs radiators don't appear to have any air in. I've had a look at the pump but there isn't a bleed screw on it. Thinking it might be some sludge I maybe dislodged frem the F & E tank blocking up the system I put some sludge remover in this morning. I've let it circulate round the system but it's still only the upstairs radiators heating up.
Any ideas how I can sort this issue out? I read another similar post like this one but thought I'd ask anyway.
Thanks for any help.
