which service valve
geordieblue
which service valve
by geordieblue » Fri Mar 14, 2008 8:25 pm
if i want to isolate the hot supply from the hot water tank to the taps, which service valve is the best one to turn off?
i`am trying d.i.y as you can see iam not very bright.
thanks for any help
by htg engineer » Sat Mar 15, 2008 12:49 pm
is there a gate valve on the hot water draw off from the tank ? normally a round red handle - if yes close this - don't overtighten as they do sheer off inside.
If not, then isolate the cold supply to the tank, by either turning off the mains stop tap - or the tank stop tap which is before the ballvalve , and let the taps run until the water stops.
geordieblue
by geordieblue » Sun Mar 16, 2008 4:25 pm
htg engineer. thanks for the help. may need to call on you again. again many thanks
It is currently Mon Jan 06, 2025 2:33 pm
