Plastering bear wa
mikey52
Plastering bear wa
by mikey52 » Sat Mar 15, 2008 9:16 pm
I am in the process of getting a few quotes for replastering my bathroom, I live in a 1930's semi with solid walls with lime based mortar, I intend to remove the existing tiles myself, back to the bear wall and just get the walls professionally replastered to take new tiles.
The first chap I had said that it was not a good idea to plaster onto walls with lime based mortar as the new plaster 'could react' with the lime and he would not gaurantee the work. He suggested 'dob & dab' with plasterboard first and then just skim the surface.
Is there such a problem with plastering straight onto the walls - afterall alot of house renovations programmes I see on the TV state that 'they had to have all the rooms replastered etc' and I assume they did not line the wall first.
Any advise appreciated.
mikey52
Plastering Bare Walls
by mikey52 » Tue Mar 18, 2008 9:13 am
Oooopps!
Subject should read [b]Plastering Bare Walls[/b]?[color=blue][/color]
matt h
by matt h » Fri Mar 28, 2008 3:00 am
with lime mixes, definately can react wuth the plaster. I normally either use hard wall then plaster over after taking back to brick, or dryline over as your friend suggested, as it saves a lot of time and gives a good finish.If you want a mor rustic look then use one coat plaster. It bonds well but the finish is not as fine as mormal top coat or multifinish :)
It is currently Sun Nov 24, 2024 1:35 am
