LOOP WIRE
jonkitch
LOOP WIRE
by jonkitch » Sun Mar 16, 2008 9:50 am
putting spotlights in bathroon,original lights have a loop where do i wire this too?
by ericmark » Sun Mar 16, 2008 4:48 pm
Please explain further loop means nothing. I will assume 12 volt as bathroom which means a transformer somewhere. Maybe you should read projects first then you have something to relate to.
by sparx » Sun Mar 16, 2008 5:14 pm
See Doc's projects 'wiring a ceiling light'
the looped lives go in a spare connector block not connected to the actual light, also you do of course know that altering the wiring in a bathroom is reportable work under bldg regs 'part-p' as explained in 'Projects' section.
It is currently Thu Jan 16, 2025 4:51 pm
