ceiling light removal
tony palmer
by tony palmer » Sun Mar 16, 2008 11:35 am
I wish to remove a ceiling light and plaster over the hole, how can I make it safe without removing any of the wires within the ceiling itself?
by ericmark » Sun Mar 16, 2008 8:59 pm
This is all dependent on access. Any cable joint using screws needs to be assessable so if you can get at in in loft then just use ceiling rose in loft. But if not assessable then it requires proper crimped joints and shrink sleeve etc.
It is currently Thu Jan 16, 2025 5:21 pm
