Lock outside tap
melodymaker
Lock outside tap
by melodymaker » Fri Apr 20, 2007 7:39 pm
Hi. I need to install an outside tap in school grounds. I must be able to use the tap when the school is closed. I won't have access to the inside of the building to turn the supply on/off from there.
There is also the issue of preventing the children from using the tap during the day.
What I need is a tap that will either lock with a key, or has a detatchable top which can be removed and kept nearby.
Any suggestions? I have searched the internet to no avail.
peter the plumber
by peter the plumber » Sun Apr 22, 2007 10:30 pm
Try installing a 22mm ball valve and just removed the handle when not in use.
A hose should go on it with a nut.
It is currently Sun Dec 22, 2024 12:07 pm
