Patio Slabs
saaitk
Patio Slabs
by saaitk » Sun Mar 16, 2008 2:59 pm
I have just moved into a house which has been empty for some time. The slabs on the patio are green and very slippery when wet. I assume thta this is some form of algae. What is the best way to remove this and clean the slabs up?
ALDA
by ALDA » Sun Mar 16, 2008 10:15 pm
PRESSURE WASHER!
citroen
by citroen » Tue May 13, 2008 7:44 pm
If you dont have a pressure washer,another method is to wash them with Jeyes Fluid.You may have to use a stiff brush or a deck scrubber,which can be hard work if you have a lot of slabs to wash.
It is currently Fri Dec 27, 2024 5:57 pm
