Laying wc on floor tiles?
6 posts   •   Page 1 of 1
Suprastone
by Suprastone » Sun Mar 16, 2008 7:18 pm
Hi i am redoing the bathroom at the moment and was wondering can i lay the floor tiles first, then place toilet on top or do i have to lay toilet first than tile around? same goes for sink pedestal?
I was going to lay on a bed of grip fill to take up any knocking etc...
Skids
by Skids » Mon Mar 17, 2008 7:58 pm
Hi Suprastone,
lay the floor first, put a ring of plumbers putty around the base of the WC pan and position on the tiles. much like for the pedestal.
Regards
Skids
Bungler
Laying WC on floor tiles
by Bungler » Mon Mar 17, 2008 9:15 pm
I’m no expert but I tiled our en suite floor first and the plumber installed toilet etc on top - much easier than cutting tiles to fit around plinth and neater too.
After tile cement and grout have set hard, rest WC in place and mark tiles through fixing holes, remove WC and drill mounting holes (I find spear bit meant for drilling glass is great for use on tiles too). Then screw in place with stainless steel or brass screws being careful not to overtighten and crack WC. Finally run silicone sealant around plinth/tiles junction.
I’ve fitted cork tiles around a couple of toilets but marking and cutting an accurate profile takes time and I'd avoid doing so with ceramic tiles if possible.
rock chicken
by rock chicken » Mon Mar 17, 2008 9:38 pm
I would advise you to lay the floor tiles first. It will look better and be easier tiling wise to save you shaping the tiles. Also it enables you to change the suite in the future as you wont have a gap in the tiles when you take the old suite out because most toilets and pedestals are different shapes.
Suprastone
by Suprastone » Tue Mar 18, 2008 9:46 pm
Thanks guys will tile tomorrow and fit toilet after,then i can stop peeing into a bucket!!!
Nester
by Nester » Wed Mar 19, 2008 2:32 am
Its worth noting that in the best bathrooms most tiling - floors and walls - is carried out prior to fitting sanitary ware. This not only makes tiling easier but it enables sanitary ware to be changed. Sanitaryware should also be centred symmetrically on tiles where possible and this means planning positions for appliances and the tiles together.
Putting a toilet on the tiles also puts the toilet at the correct design height which is fairly standard at 40cm.
It is currently Fri Nov 22, 2024 4:44 am
