Bedding plastic frames of inspection covers
Edith Klemesrud
by Edith Klemesrud » Mon Mar 17, 2008 10:50 am
Do you still bed the plastic frames in cement as you did with the old steel frames or is there a special grout also for double sealed do you bed frame separately or leave cover bolted on when you bed frame? Whole thing will be buried in screed eventually so no access required from my property as I have a new inspection chamber externally.
Grateful for any input
It is currently Mon Dec 02, 2024 8:35 pm
