Bath hot water pipe size
6 posts   •   Page 1 of 1
barkby123
by barkby123 » Mon Mar 17, 2008 2:29 pm
I'm changing my bathroom round and want to put the bath where the sink was. The hot water supply to the sink is a 15mm spur from the 22mm supply that enters the bathroom. Do I need to replace all the 15mm pipework to where the bath will be with 22mm, or is it only necessary to add a small section of 22mm to connect to the bath tap?
Rico
by Rico » Tue Mar 18, 2008 9:07 am
barkby,
It depends on what water system your on combi boiler or cylinder.
If combi you can use the existing pipe work and get some 3/4 inch - 15mm flexi hoses.
If water comes from cylinder then you will need to replace 15mm with 22mm to get a decent flow rate to the bath.
Hope this helps
Rico
Skids
by Skids » Tue Mar 18, 2008 12:33 pm
Hi Barkby123
its all about flow and pressure.
if you have a combi boiler, you should be ok, as you should have 1.5 bar + of pressure.
if you are running from a HWC, it may be slower as there is less head of pressure from the CWSC and with a smaller pipe (15) the flow will be down.
if you can change to 22mm for the bath all the better (faster), however it's not going to harm just be slower to fill.
Regards
Skids
by htg engineer » Tue Mar 18, 2008 6:01 pm
All depends on where your hot water is fed from, if from a tank or cylinder it should be 22mm from tank or cylinder to bath.
If it's a combi, it can be 15mm from boiler to bath
barkby123
by barkby123 » Tue Mar 18, 2008 8:36 pm
Thanks for all your replies. 22mm it is then.
Re: Bath hot water pipe size
by htg engineer » Tue Oct 16, 2012 7:49 pm
Don't use flexi hoses -they're rubbish, have seen/known of many splitting. This happened in my house, I installed the upstairs bathroom, 2 years later the flexi hose split - luckily we had just went to bed after using this bathroom and I heard the water running - if we'd been asleep the ceilings downstairs would have come down and who knows what other damage would have been caused.
It is currently Tue Jan 07, 2025 9:32 pm
