radiator / boiler problem
9 posts   •   Page 1 of 1
mrchristoph
by mrchristoph » Mon Mar 17, 2008 4:43 pm
I have changed a traditional radiator for a towel radiator in the bathroom. It is very hot at the bottom but not middle up, despite constant bleeding of valve. In fact, all upstairs radiators have been bled but water not coming out. NOW, boiler is making a windy noise as it is working which is very disturbing. The boiler is still working and all radiators/hot water ok. Any advice??
Rico
by Rico » Tue Mar 18, 2008 9:08 am
mrchristoph,
Can you tell us what heating system you have.
TYpe of boiler, do you have combi or cylinder.
Rico
by htg engineer » Tue Mar 18, 2008 6:03 pm
Type of boiler, you system is not full of water - when you open the bleed vent on the towel rail - water should be present.
Your system could need re-pressurising, or it could be airlocked or a blockage
mrchristoph
by mrchristoph » Wed Mar 19, 2008 5:26 pm
thanks, we have a combi boiler in a new house.
by htg engineer » Thu Mar 20, 2008 9:27 pm
what's the pressure gauge reading ? (on the boiler) should be between 1.0 and 1.5 bar.
Read boiler manual - it should tell you how to re-pressurise system
mrchristoph
by mrchristoph » Fri Mar 21, 2008 4:49 pm
If only i could find the manual! will try to find on internet though
by htg engineer » Fri Mar 21, 2008 9:11 pm
Boiler make and model ?
Is there 2 valves under the boiler capped or connected with a flexi hose ?
if there is - this is the filling loop,
mrchristoph
by mrchristoph » Sat Mar 22, 2008 1:29 pm
I am looking at the expansion vessel pressure valve which is at 0 whether heating is on or not. As per other topics have tried a bike pump but this is almost impossible to pump. in fact. when taking valve off more air seems to come out than i had got in.
by htg engineer » Sat Mar 22, 2008 4:58 pm
Completely wrong - you're trying to re-pressurise with air - the system needs to be re-pressurised with water and not the expansion vessel (so don't try filling vessel with water).
Get a heating engineer out as you don't seem to have a clue how the system works - otherwise you're going to end up making a simple job into a bigger more expensive one.
You'll now also need to have expansion vessel pressure checked.
It is currently Tue Jan 07, 2025 9:03 pm
